Diagnostika vead
Postitatud: 21.05.2007 13:27 41
Kas keegi oskab midagi nende veakirjelduste peale kosta?
Auto 525tdsA E34 95'
1. Diagnosis DDE faults
41 Glow-duration control not functioning
Fault not currently present
Not been detected for 14 starts
Detected at:
Engine speed 705 rpm
Engine temperature 65C
2. Diagnosis EGS faults
43 Engine speed signal (td signal pin 43 on SG)
Fault has been recorded as fault 1
no or incorrect engine-speed information
3. Diagnosis EGS faults
42 Output-speed sensor n-ab
Stall-speed monitoring (pins 14-, 42+ on SG)
Fault has been recorded as fault 2
No or incorrect engine speed information
4. Diagnosis EGS faults
53 Power supply for solenoid valves (pin 53 on SG)
Fault has been recorded as fault 3
Gearbox relay in EGS SG cannot drop out
Detected at:
