				About 2008 E61 Help
				Postitatud: 24.11.2022 22:02 39
				Postitas e61white
				Hello everyone,
First of all, I apologize for writing in English. I'm new to Estonia and I own a 2008 model e61. I want to get information on some subjects that I do not know and I think I can find the most accurate information here.
What happens if the vehicle does not have a spare tire during the technical inspection?
Is it okay if the tire dimensions differ from the factory data during the technical inspection? Also, the car has flanges and the wheels are offset.
Where can I find a spare wheel set for my car?
Where should I buy the first aid kit and fire extinguisher?
				Re: About 2008 E61 Help
				Postitatud: 25.11.2022 08:44 00
				Postitas Raghza
				They don't usually check if you have a spare tire or not, but you need to have two wheel chocks.
As long as the wheels don't poke out too much and you have all the wheel bolts, you don't have to worry about the spacers.
If your tires are fine and not ridiculously oversized, nobody usually checks if they're within factory specified dimensions or not.
You can get the first aid kit and a fire extinguisher from every supermarket or a parts shop.
				Postitatud: 25.11.2022 11:22 46
				Postitas RazzKalbass
				No, you cant passs MOT with spacers if they see it..UNLESS you have certs.
				Postitatud: 28.11.2022 13:06 31
				Postitas e61white
				Thank you so much for answering
				Postitatud: 28.11.2022 22:40 14
				Postitas Kert11
				First aid kit is not mandatory if private car. It is mandatory only companie owned cars
				Postitatud: 29.11.2022 13:25 50
				Postitas e61white
				Kert11 kirjutas: 28.11.2022 22:40 14
My car does not belong to the company. Just on me. So, if I don't have a fire extinguisher and a first aid kit, will the car pass technical inspection?
				Postitatud: 29.11.2022 13:34 39
				Postitas Kert11
				if private car:
fire extinguisher - mandatory, also that needs to be not older than 10 years, also needs to have yearly verification (valid date on it)
first aid kit - optional, not needed inspection perspective
				Postitatud: 29.11.2022 21:32 40
				Postitas MairoG
				e61white kirjutas: 29.11.2022 13:25 50
Yeah, you will pass   MOT   without them.  So   dont worry  about  those.   But     it`s  good  to have them both, whenever  you need them.
				Postitatud: 30.11.2022 08:06 45
				Postitas Herts
				Postitatud: 25.12.2022 18:24 57
				Postitas e61white
				Thank you so much everyone for the replies, I also want to ask a question. What are safety shoes? Can you give an example of a picture please?
				Postitatud: 25.12.2022 19:05 07
				Postitas MairoG
				Postitatud: 25.12.2022 21:16 22
				e61white kirjutas: 25.12.2022 18:24 57
				Postitatud: 25.12.2022 22:01 10
				Postitas LEDBeam
				Postitatud: 26.12.2022 01:32 09
				Postitas e61white
yes I guess this. thank you for your help
[/quote]
"ohukolmnurk ja rehvivahetuseks teel ettenähtud tõkiskingad"
I'm not so sure that's what's written here. I think I asked wrong
				Postitatud: 26.12.2022 08:05 21
				Postitas Jaanus_V
				It says "warning triangle and chochs for changing tires on the road"
Safety shoes for people are like the ones above. Safety shoes for cars are like Ledbeam posted but they are more known as chocks, not safety shoes. Could have asked better. If you take one sentance out of the content and translate it, then these things will happen.
https://www.google.com/search?q=t%C3%B5 ... dsTf67l_HM
				Postitatud: 02.01.2023 17:57 17
				Postitas e61white
				Hello again
I took my car for technical inspection and I couldn't get approval because of the problem in the photo I attached. Where can I find this part and where can I get it done? Thanks in advance for your help.
SHARNIIR;
OV 5.1.2. Kaändmik.: 5. 1.2.2. Kaändteljepolt või kuulligend või puksid on Ulemäära kulunud. Lisainfo: ESISILLA PAREM TAGUMINE
				Postitatud: 02.01.2023 18:09 43
				Postitas toivoku
				one of the wishbones is worn out, i can help you with parts and replacement
