vihma sensor
vihma sensor
mure siis selline et 2002 e39 vihma sensor ei toimi ainult intervall,inpa veateateid ei nãita autol orinaal klaas,proovisin sensorit vahetada aga ei midagi,oskab keegi mingit nōu anda voi ise aidata
						Re: vihma sensor
midagi inpaga tegin ja üks tuttav proovis ka aga ei midagi
						Re: vihma sensor
Initialisation
Due to the optical process, the rain sensor has to be adapted to the windscreen. This adaptation takes place at initialisation.
Requirement for faultless initialisation is that the windscreen glass is dry, clean and free of defects in the area of the rain sensor.
The initialisation is performed using the service function ”Initialise rain sensor” in the BMW diagnosis system. In the service function, the adaptation values in the rain sensor are deleted. This is followed by adjustment of the sensor system to the windscreen based on the following sequence:
- Switching off the rain sensor
- Switch off terminal 15 and terminal R
- Switch on terminal R and terminal 15 and wait 10 seconds
In the 10 seconds waiting period, the new adaptation values are determined and stored.
Initialisation of the rain sensor is necessary:
- After replacing the windscreen
- Fitting a used rain-driving light sensor
Note: a used sensor must be coded beforehand!
Buumer Auto / 56826000
						Re: vihma sensor
mis on terminal 15 ja terminal L.ãkki seletad lollile,ei mãleta mida sal inpaga valisin aga mingit sellist protseduuri ma lãbi ei teinud
				ttsys
Re: vihma sensor
O = off
KL 15 (terminal 15) or "run bus" (ignition switch run position) = ignition position 1
KL 30 (terminal 30) or "battery bus" (hot at all times) = ignition position 2
KL R (accessory bus) = ignition position 2
KL 50 (terminal 50) or "start bus" (ignition start position) = ignition position 3 (start)
Lisaks DIN72552 standard:
http://www.bosch-classic.com/media/en/b ... nungen.pdf
Re: vihma sensor
loll tunnistada aga ei saa aru mis ja kuidas pean tegema kas algul inpaga panen kalibreerimise ja siis mängin süütega või see 2 erinevat teemat.mul inpa olemas aga ei ole seda väga kasutanud.seletage palun kohalikus keeles
Re: vihma sensor
kas oskab keegi vihmasensorit kalibreerida.kas õpetada või ise teha,tasun vaeva
						Re: vihma sensor
Kas tõesti ei oska keegi aidata?
				ttsys
Re: vihma sensor
Täpsemalt kirjeldades ei ole seal midagi kalibreerida. Ainus asi, mida saab teha on anduri initsialiseerimine.
Jääb mulje, et antud juhul pelgalt sellest initsialiseeringust ei pruugi abi olla ehk viga on mujal, kui pelgalt anduris ning selle initsialiseeringus. Võimalik, et läätsega midagi valesti(?)
Seega jooksvalt nn initsialiseeringuga peale lendamine ei pruugi lahendust tekitada. Vaja on kõik komponendid käepärast omada, et lahendus tekitada. Pelgalt initsiatiivist see korda teha jääb ilmselt väheks.
Re: vihma sensor
proovisin ka sensorit vahetada aga lääts jäi vana kui klaasi vaadata on lääts ilusti õhku vahel pole ja ees originaal klaas
				ttsys
Re: vihma sensor
Kõik tore aga siis peab süsteem reeglina kuidagi moodi ehk kasvõi hädiselt kohe töötama. Kui vee klaasile piserdamine ka kõige tundlikumas asendis mitte midagi ei muuda siis suure-suure tõenäosusega ei ravi seda ka initsialiseerimine.
						Re: vihma sensor
autol töötab intervall aga sensor järgi ei lähe
täna tuttav proovib veel boschi diagnostiga,aga mis teha soovitad
				ttsys
Re: vihma sensor
BMW ISTA/D teeb initsialiseeringu protsessi nagu BMW-le vaja ning eeldatud. KTS-i teostuse kohta ei arva midagi.
Mis mul ikka rohkem soovitada. Otsusta ise ära, kas soovid maksta pelgalt süsteemi initsialiseerimise eest, mis ei pruugi mitte midagi lahendada või soov ühe korraga vajalik lahendus tekitada. Viimane eeldab, et vajadusel kõik kompenendid kohapeal olemas ning remondile järgneb nõutud initsialiseerimise protsess.
Re: vihma sensor
mida sa remondi all silmas pead mille ma siis soetama peaks sensori koos lããtsega aga mis veel???
				ttsys
Re: vihma sensor
Võid vaadata seda tüüpi DIY läbi;
http://forum.e46fanatics.com/showthread ... highlight=
E39, E46 jne sama andur;
http://www.realoem.com/bmw/enUS/showpar ... Id=61_0169
Re: vihma sensor
olen vahetanud sensorit teinud seda kalibreerimist ei midagi proovisin ka aktiveerimist ikka on ainult intervall. ehk oskab keegi veel mingit ideed pakkuda mis mind edasi aitab
						Re: vihma sensor
Mul ei tööta vihmasensor ega intervall. Millest alustada?
Isegi kiirusetundlikus ei tööta kojameestel ehk, kui kojamehed on kõige kiiremas asendis ja jääda seisma, siis pühivad ikka täiega edasi.
- oke139
- Peamine sõiduk: Fx
Re: vihma sensor
Alusta diagnostikast?
						Re: vihma sensor
Tegin diagnostika ja näitas et vihmasensori plokk ei tööta. Kas see mõjutab intervalli kiirust ka?
				ttsys
Re: vihma sensor
Otseselt sellega seotud.
						Re: vihma sensor
Suur tänu!
						Re: vihma sensor
Minule ka mõnda ideed mida katsetada
				ttsys
Re: vihma sensor
Post #4 kirjeldatud initsialiseering teha ISTA/D-ga.
						Re: vihma sensor
tehtud manuaalselt,inpaga,auto com iga ja bosch diagnostiga ei aidanud ikka ainult intervall
				ttsys
Re: vihma sensor
Kui usaldad neid töövahendeid siis ju lihtne. Osta uus moodul.
						Re: vihma sensor
Olgu ostan!kus asub ja milline väljanäeb ehk pakub keegi
						Re: vihma sensor
ehk keegi pakub 2002 e39 vihmasensori moodulit
