725tds ecupinout
Andres_K
Peamine sõiduk: 320D A 2002a
725tds ecupinout
Postitus Postitas Andres_K »
Tere. Äkki keegi saab joonise anda, kus on ecu pinoutid( mootori aju) välja toodud? Äitäh
Peamine sõiduk: Polestar 2
Re: 725tds ecupinout
Pin Type Description / Signal type Connection /
Measuring notes
1 A Activation of fuel quantity control unit (MSO) Fuel quantity control unit in injection pump
2 A Activation of fuel quantity control unit (MSO) Fuel quantity control unit in injection pump
3 A Activation of electrical cut-out (ELAB) Electrical cut-out valve on distributor-injection pump
4 A Activation, preheating indicator/DDE (LA1) High: Light module, Basic: Instrument cluster
5 E Signal, needle movement sensor (NBF1) Start of injection sensor in injection nozzle (SD nozzle), cylinder 4
6 A Activation of electropneumatic pressure converter for exhaust gas recirculation (AGR0) Electropneumatic pressure converter for controlled exhaust gas recirculation
7 Not used
8 A Activation of preheater time control (GZS) Glow plug relay
9 A Activation of controlled damping engine mount (DSL0) Electrical changeover valve for engine mount activation
10 A Activation of solenoid valve for injection timing device (MV0) Solenoid valve for injection timing device in distributor-injection pump
11 A Activation of FGR lamp (FGR-L) FGR lamp in instrument cluster
12 M Ground, needle movement sensor (NBF0) Ground supply for start of injection sensor in permanent injection nozzle (SD nozzle), cylinder 4
13 M Sensor ground for shield and sensor (31M) Ground, or shield for sensor and transmitter
14 E Control part sensor center pick-off (RWG-Y) Center pick-off of 2 coils of HDK sensor in distributor-injection pump
15 A Activation of DDE main relay (HRL) DDE main relay
16 E Supply voltage B + (30ES) Fuse F1, Fuse carrier, engine electronics
17 E Supply voltage B + (30ES) Fuse F1, Fuse carrier, engine electronics
18 M Ground B- (BAT-) Ground splice
19 M Ground B- (BAT-) Ground splice
20 Not used
21 A Control path sensor reference coil (RWG-R) Reference coil of HDK sensor in distributor-injection pump
22 Not used
23 A A/C compressor activation from DDE control unit (KOA) Heating and A/C control module
24 E A/C compressor request from IHK control unit (S-KO) Heating and A/C control module
25 E Pedal position sensor idle switch (PWGL) Idle switch in pedal position sensor
26 E Brake light switch BRL (BL-ON) Brake light switch
27 Not used
28 E Clutch switch (KUS, for HG only) Clutch pedal position switch
29 E Vehicle speed signal (DZF-HR) Connector for rear right wheel speed
30 E FGR main switch (FGR-MS) FGR main switch on instrument panel
31 E Brake light test switch BRT (B-EML) Brake light switch
32 E Cruise control (FGR) Multifunction steering wheel control module
33 A Voltage supply for pedal position sensor (PWG2) Pedal position sensor potentiometer
34 A Voltage supply for hot-film mass air flow sensor (LMM2) Hot-film mass air flow sensor
35 E Fuel temperature sensor (KTF1) Injection pump, Distributor
36 E Engine oil temperature sensor (OTF1) Temperature sensor, engine oil at oil filter
37 E Signal, pedal position sensor (PWG1) Pedal position sensor potentiometer
38 E Hot-film mass air flow sensor signal (LMM1) Hot-film mass air flow sensor
39 A Control path sensor, reference coil (RWG-M) Measuring coil of HDK sensor in distributor-type injection pump
40 E/A CAN interface CAN-LOW (CAN-L) CAN-bus
41 E Diagnostic trouble code, preheater plug relay (DIA) Glow plug relay
42 E/A Diagnostic interface (DS) Splice TXD
43 E/A CAN interface CAN-HIGH (CAN-H) CAN-bus
44 E Air conditioning system switch (S-AC) Heating and A/C control module
45 E Signal, electronic immobilizer EWS (S-DWA) Electronic drive-away protection control unit (EWS)
46 A Activation of relay for fuel pump (EKP) Fuel pump relay
47 E Speed (rpm) sensor (DZG1) Speed (rpm) sensor
48 Not used
49 A Load signal output (TQ) Integrated instrument cluster control module (IKE)
50 A Engine speed signal output (TD) Integrated instrument cluster control module (IKE), Data link connector
51 A Voltage supply, boost pressure sensor (LDF2) Boost pressure sensor
52 Not used
53 E Engine coolant temperature sensor (WTF1) Dual temperature sensor in cylinder head
54 E Signal, boost pressure sensor (LDF1) Boost pressure sensor
55 E Control input, ignition lock (K15-E) Fuse F24
Kui jooniseid ka vaja, siis pead ise vahtima:
http://www.bmw-planet.com/diagrams/rele ... /index.htm" onclick="window.open(this.href);return false;
Adobe SVG Viewer 3.0 vaja installida et zoomida saaks.
