Kas keegi oskab midagi nende veakirjelduste peale kosta?
Auto 525tdsA E34 95'
1. Diagnosis DDE faults
41 Glow-duration control not functioning
Fault not currently present
Not been detected for 14 starts
Detected at:
Engine speed 705 rpm
Engine temperature 65C
2. Diagnosis EGS faults
43 Engine speed signal (td signal pin 43 on SG)
Fault has been recorded as fault 1
no or incorrect engine-speed information
3. Diagnosis EGS faults
42 Output-speed sensor n-ab
Stall-speed monitoring (pins 14-, 42+ on SG)
Fault has been recorded as fault 2
No or incorrect engine speed information
4. Diagnosis EGS faults
53 Power supply for solenoid valves (pin 53 on SG)
Fault has been recorded as fault 3
Gearbox relay in EGS SG cannot drop out
Diagnostika vead
http://www.google.ee/webhp?hl=et
Kuid ausalt öeldes ei ole lahtiseletamisest huvitatud, kuna pere ninaesine sõltub sellest otseselt
Ja mitte ainult minul
No hard feelings!
Ja üldse, kuidas need veateated kätte said? Carsoft?
Oskab küllKas keegi oskab midagi nende veakirjelduste peale kosta?
No hard feelings!
vastus truumule
Saan aru
, aga
äkki oskad öelda, kui palju ma rahakotti tühjendama pean umbes nende vigade likvideerimiseks. Ja veateadete kätte saamiseks oli abiks ikka "vana hea" (loe mõttetu koht) UM.
