Vahetasin f11-l elektrilise roolilati teise vastu ning nüüd vaja kodeerida. CAFD injectimine EPS-i lõpeb erroriga.
EPS [30]
cdDeploy FinishedWithError
cafd_00000e74-005_004_000 FinishedWithError
Auto istep on 15-03-502, aga kui valin CAFD, siis seal on istepid 13-07-501 ehk vanemad? v.4.53.21_PSdZData_Lite on mul viimane mida eile jagati bimmerfestis. Või on miski muu viga.
Esys on 3.30.1
Kood: Vali kõik
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
Read SVT before TAL execution started.
Read SVT before TAL execution finished.
VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197]
ExecutionID=2025/05/17-11:54:33.486
[] prepareTALExecution started [PROGRESS]
[] prepareTALExecution finished [PROGRESS]
[] prepareVehicleForCoding started [PROGRESS]
[] prepareVehicleForCoding finished [PROGRESS]
[EPS - 30] prepareECUforCoding started [PROGRESS]
[EPS - 30] prepareECUforCoding finished [PROGRESS]
[EPS - 30] authenticateECUforCoding started [PROGRESS]
[EPS - 30] authenticateECUforCoding finished [PROGRESS]
[EPS - 30 - cafd_00000e74-005_004_000] Transaction type: cdDeploy;  Message: TA started [TRANSACTION]
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=EPS_30_ETHERNET> [DIAGSERVICE]
[] job failed with negative response error:
 code: repeat job
 description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: EPS_30_ETHERNET
 severity: ERROR
 [THROWABLE]
[EPS - 30 - cafd_00000e74-005_004_000] Transaction type: cdDeploy;  Message: TA finished [TRANSACTION]
[EPS - 30] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
 code: repeat job
 severity: ERROR
 [WARN]
[EPS - 30] - [Exception - EPS - 30] job failed with negative response error:
 code: repeat job
 severity: ERROR
 code: repeat job
 severity: ERROR
 [THROWABLE]
[EPS - 30] There was an error during TAL execution, please check the log files. [WARN]
 code: repeat job
 severity: ERROR
[EPS - 30] finalizeECUCoding started [PROGRESS]
[EPS - 30] finalizeECUCoding finished [PROGRESS]
[] There was an error, please check the log files. [WARN]
[] - [Exception - EPS - 30] job failed with negative response error:
 code: repeat job
 severity: ERROR
[] finalizeVehicleCoding started [PROGRESS]
[] finalizeVehicleCoding finished [PROGRESS]
[] finalizeTALExecution started [PROGRESS]
[] finalizeTALExecution finished [PROGRESS]
TAL execution finished [TAL_EXECUTION_FINISHED]
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "7s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Abarbeitung beendet
