E61 kellaaeg ja kuupäev
Hannes
- Peamine sõiduk: E91 325d
pidevalt on kell ja kuupäev nullis. Vahepeal ka kesk. Kütusekulu. Nagu öösel millalgi poleks voolu olnud. Aku korralik ja käivitub hästi. Kunagi oli akukastis vett, äkki sellest mingi jama...
(OO==[][]==OO)
ttsys
Re: E61 kellaaeg ja kuupäev
Kulunud diisel, mida käivitad pidevalt väliste abivahenditega?
Hannes
Diisel küll aga mitte kulunud. Ja nagu mainisin siis aku korralik ja käivitub ilusti
(OO==[][]==OO)
iDrive errorit lööb?
ilmselt aku viga
aasta?
ilmselt aku viga
aasta?
- PeeterA
- Telefon: 51949859
Ei tasu kohe uut akut ostma tormata:
Kood: Vali kõik
Instrument cluster: power supply switched off
Symptoms:
The time and date in the instrument cluster and in the Central Information Display are lost.
The fault code memory entry ”instrument cluster: power supply switched off” is stored in the instrument cluster.
Cause:
The fault code memory entry does not indicate a defect in the instrument cluster or in the power supply of the instrument cluster, rather only disconnection of the power supply of the instrument cluster by the KGM: reset or cut off terminal 30g-f.
Reset or cutoff of terminal 30g-f is due to a fault in the vehicle: too many wakings with terminal R Off, closed-circuit current fault, sleeping inhibited, reaching the starting capability limit.
Procedure:
If there is an impairment (e.g. time was lost; see above symptoms), the test module 'Energy diagnosis' helps in finding the cause of the problem in the vehicle energy system: run the test module.
If the vehicle had a breakdown due to a flat battery despite the reset or cutoff of terminal 30g-f, it is usually the case that the control units supplied via this terminal are not the likely cause.
ttsys
Aku ise vaevalt vealine. pigem IBS või mingi haige tarbija sekkub jne.
- PeeterA
- Telefon: 51949859
Diagnostika tuleks teha ja kontrollida, mispärast keremoodul toite lahti ühendab.
