E39 Siemens Bit 2 telefon "Equipment Code"
Sten.H
Peamine sõiduk: BMW X5 3.0d E53 FL ´04
Postitus Postitas Sten.H »
Tere!
Kuna omal oli probleem selle telefoniga vahepeal tänu oma lollusele siis telefon küsis mul Equipment Codei. Tükk aega otsisin ja siis lõpuks leidsin ka lahenduse, lisan selle lahenduse ka siia, äkki on kellelgi sama probleem.
Võetud see Bimmerfest foorumist:
I have now got my Siemens Bit II cordless phone running again
Here how to do :
1 : Cordless phone unit on and out of eject-box , and switch in buttom of
eject-box in pos. I ( on )
2 : Ignition key in pos. 1 for excaxtly 15 sec.
3 : Ignition off for 8 sec.
4 : Switch in ejext-box in pos. 0 (off ) for 2 sec. and then on again
5 : Ignition key in pos. 1 , and now put in the unit code for the cordless
phone , unit code : " 0 0 0 0 " and then accept ( ok )
Be please be awer that the times must be excaktly 15/8/2 sec. , use a
stopwatch or something a`like.
Ehk on abiks kellelegi :)
BMW X5 3.0d E53 FL Maritime 2004 (160kw/500Nm)
alartolk
Peamine sõiduk: BMW 318 m-pakett
Re: E39 Siemens Bit 2 telefon "Equipment Code"
Postitus Postitas alartolk »
ei saa päris hästi pihta sellele :P oskad äkki seletada.
