Cool! Thanks bro! It's been a ton of work, so nice to hear some compliments.. Here's quick glimpse what the car's been through.. Needless to say it has been a pain in the a** some times...
 I didn't bother to start and translate all this crap so just ran it through Google Transalte - hope this gives you an idea..
:: Summer 2008 Spring 2009 ( the previous owner ) ::
- Oil change , filter , ilmanputsari , plugs, etc., the coolant to the spring and autumn
- Sides of the wires
- Brake pads front
- Preserved in the garage for the winter
:: Summer 2009 - Fall 2009 ::
- Height adjustable suspension kit
- Iskarien the upper ends of the front and rear
- New rubber blast
- Black kidney model facelift look
- Oil change , filter , ilmanputsari , plugs, etc. basic maintenance of the coolant to
- Store in a warm garage for the winter
:: Winter 2009 - Spring 2010 ::
- New front lower arms
- Powerflex eccentric lower control arms takaheloihin
- Lamin-X - lined headlights, turn signals , and sumarit
- Started the endless puskurinkorjausproggis ..
- Winter car in custody until the beginning of March , April, driving into the side
- New rear window
- Thermostat ( temperatures do not rise properly)
- DME replaced ( vitosmukin nozzle control earth fault)
- Changed lambda (old blacked out )
Summer 2010 :: ::
- Tie rods renovated
- Car rear tray mounts vahvikehitsattu
- All of the rear carriage bushings were replaced OEM parts
- Powerflex cams while under the front ( previous crack ....)
- Change in substrate inspection
- New rubber rear 245/35/17 front and 215/40/17
- New front indicators model for smoke
- All lights + headlights and sumarit lined with Lamin-X tint - shade
- Box oils, clutch / brake fluids
- Used a new flywheel
- A new clutch slave cylinder
- Puuhasteltu more headroom etucämpereihin
- A new clutch slave cylinder ( again , thank you Motonet )
- New clutch master cylinder
- Ovipahvien nipukat changed and cardboard liimailtu condition
Fall :: 2010 ::
- New models OEM aluminum topmount front
- Propeller shaft support bearing
- New Rear Camber
- LED license plate lights
- Right front wheel hub / bearing replaced
- A new flekti
- Oil change, oil filter , ilmanputsari
- A new front bumper design M
- Hardtop
- The car stand up after the snow income
Winter 2010 :: ::
- New wheels Rondell 0058 10x17 ET15
- 5mm spacers in front
- water pump
- ribbed belt
- LEDs interior lights
- Valve cover gasket, rubber gaskets and bolts
- Piiloventtiilit wheels
- New wheel bolts
- Big OBC 's vilkunviiksi
- Fixed seat
- Interior cleaning benches
- Repair stitched seams front seats
Spring 2011 :: ::
- The car driving in April
- 3mm to 5mm spacers in place of
- New rubber 4x 225/35/17
- A new stage box 138tkm
- Step in the box all the seals + gaskets
- Crankshaft oil seal + gasket
- Shift bush set
- Hard flywheel ( non- vanos M50 )
- 15tkm mileage kykäsetti + new thrust bearing
- The engine mounting rubbers ( yet to install )
- The gearbox support rubber
- Propeller shaft rag joint
- H1 LEDs sumareihin
- Mounted electric flekti
- A new air intake accordion tube
- ilmanputsari
- New plugs
- Oil change, oil filter ( 210tkm )
- Xenons relejohtosarja
- ribbed belt
- V-ribbed belt pulley
Summer 2011 :: ::
- Brake pads front
- Intact motor protective plastic
- M takadiffu
- United OBC
- New brake pads front ( 26.7.2011 )
- New windshield ( 29.7.2011 )
- The paint milling ( 31.7.2011 )
- A new front bumper ( 4.8.2011 )
- 15mm spacers rear ( 10.8.2011 )
Fall 2011 :: ::
- Used a new wiper linkage ( 8.10.2011 )
- Warranty 160tkm gearbox with new seals
- I stand in October , the cold and dry winter storage
Winter 2012 :: ::
- New front sisälokarit
- The gearbox 160tkm
- New gearbox seals
- A new flywheel bearing eye
- The new height / stiffness adjustable suspension kit front camber adjustment : BC Racing BR
- New longer thrust bearing ( e21 323i )
- Brace in the engine room
- A new relejohtosarja xenoneille
- Gear knob illuminated
- Resistors xenoneille
- cardan
- A new propeller shaft support bearing
- New wheels BBS RS Style 10x17 ET15
- New rubber 225/35
- A new clutch disc and pressure plate
- Oil ( Castrol Magntec ) , filter , ilmanputsari (222 tkm )
Spring 2012 :: ::
- Changed door microswitches
- New 4smd lediparkit
- Outdoor temperature sensor ( installed )
- Rear spacers 15mm -> 20mm
- M3 254cc injectors -> RE85
- New DEPO 's bulbs
- Angel eyesien relejohtosarja
- 8000K xenon too long
- Xenon long relejohtosarja
- Intact M3 steering wheel and a new slipring
Summer 2012 :: ::
- Support box gums and nuts
- New sumarit and muovikehikot and mounts
- BMW list section of the front bumper and the other new listings
- 8000K xenon also sumareihin
- Box oils ( Castrol Transmax Z) ( 228tkm )
- A new front bumper with mesh .. AGAIN
- Rear lights kalvotettu Lamin-X Tint
- Sumarit kalvotettu Lamin-X yellow
- A new 88CEL Termar
- Termarikotelon seal
- New BC Racing springs , front and rear 160mm 10kg 14kg 140mm
- Propeller shaft bearing and the rag joint
- New exhaust kannakekumit
- E85 engine control provided for , the old chip in a safe place
Fall 2012 :: ::
- New strings behind the BC Racing 14kg 120mm
- Oil , filter and ilmanputsarin exchange ( 235tkm )
- The neo Boombox
- CARPOWER Sonic 10 " subi
- DLS CA-12 Amplifier
- Ground zero 1F Concha
- Slip-up the exchange of driver's rear corner of the scheme are vetari , Trailing and the supporting arm
- New wheels Carline CM6 9x17 and 11x17 ET20 ET ~ 20 w / 245/35 and 225/35
- Store in a warm car in the first frosts came in early December
Winter 2012 :: ::
- New battery Bosch S5
- The amplifier and the Konkan new wiring
Winter 2013 :: ::
- Takaventeisiin new Lipit 4 " in front and 3.5 " -> ET7 specs of 10x17 / 11.5 x17ET14
- Rear subframe Strongflex - bush set
- The rear subframe pitkittäispusla
- Stern bushes
- All new arms bushes Stronglexiltä
- New Ylätukivarsi balls back down Strongflexit
- New stabilizer link rear
- Brake pads front and rear
- Brake discs front and rear
- All new brake disc mounting screws
- The parking brake pads on both sides of the
- All hand-brake screws, springs , etc hilppeet
- All new brake hoses front and rear
- Both front lower control arms Meyle HD w / Powerflex eccentric
- M3 lists
- Origin Murikka back cover replacement
- The back of the M- Sport Stabilizer
Spring 2013 :: ::
- The upper and lower radiator hose
- BMW OEM Wind Screen
- New wipers
- Plugs Bosch FGR7DQP
- Rear brake pipe clips
- A new kuskinpuolimmainen Rear lower end of the
- 66SMD Led angel Eyesite place
Summer 2013 ::
- The whole body recoating , rust protection and arcs processing , antenna removed and all klommot oikastu
- Brake pad wear sensor front
- The rear registration plate door stoppers
- Umpioiden säätönipukat and their screws
- New M3 Facelift look black kidney
- Facelift side indicators
- New, dark front indicators
- Facelift front fenders and their distribution
- The new Bosch lambda ori
- The new M3 front bumper
- The new M3 rear bumper
- New left inner fender
- jenkkiparkkimodulit
- New door handles frames and seals
- A new housing sub I
- Plastic bag of new screws , fasteners and klilpsejä
- Poly-V belt , ribbed belt rollers exchange
- Tire balancing
- Jenkkiparkkimodulien compensation on the heels of the U.S.
- New takaläskit Falken FK -452 245/35/17
- Fan coupling and flekti
- Toe-in angle adjustment
