E46: Signa puldi aku tühi?
juss17
Postitus Postitas juss17 »
Tere mureks siis enda auto puldiga.
Auto siis Bmw e46 325ci 2002a
Pult enam ei toimi ei ava uksi ega sulge neid enam, eelmistel päevadel lihtsalt pidin mitu korda vajutama nuppu et asi lukku läheks või siis avaneks.Läksin patareid vahetama aga öeldi et seda pulti nemad lahti ei saa teha ja üldse seal sees on aku.Väga halb on see et autol on ainult üks pult, teine on kadunud.
Olen kuulnud et on ise võimalik kuidagi autole tutvustada pulti?
Tarmo
Peamine sõiduk: Porsche Cayenne '14
Re: E46: Signa puldi aku tühi?
Postitus Postitas Tarmo »
Tutvustamise koha pealt jään vastuse võlgu , aga see peaks ennast süütelukust laadima jah.
Keera võtmega uks lahti ja mine sõida vähe pikemalt , äkki laeb ennast täis.
Tutvustamise osas uuri kas Patrikult või UM-ist.
Edit:
leidsin netist sellise õpetuse
Quote:
Originally Posted by Marksr
My new spare key (the one that looks like an elongated hexagon) for my '04 M3 arrived in the mail from the dealer. The problem is that the lock/unlock doors buttons on the key don't work. Here are my questions:
1. Does the key contain a battery that's replaceable and if so, how do I access it?
2. How can I initialize the key so that it will at least lock and unlock the doors & trunk? I don't necessarily want to program it, I just want these basic functions.
3. For future reference, is there a way for an owner to program the key without taking it to the dealer?
The battery is not replaceable, it recharges itself while driving with that key.
I do not know what you mean by "programming the key" but you can initialize the key to lock, unlock the doors and the trunk remotely.
I think this is how you do it (I have not done it myself as I did not have a need to do it):
All doors closed insert key into ignition and turn key from the off position to position 2, 5 times @ 1 sec intervals (each time you turn to position 2 the OBC will come on).
Remove key and immediately press and hold the UNLOCK button and then press the ROUNDEL button 3 times and then let go of the UNLOCK button.
Now it should lock unlock the doors and the trunk
Try it and post if it works or not.
Ja kodaniku väitel kellel see probleem oli väitis et töötab.
gamer112
Peamine sõiduk: bmw 320d e46
Postitus Postitas gamer112 »
esinduses maksab tutvustus kas oli 50-80 eeki... ise proovisin ka õpetuse järgi, aga ei toiminud.
..heigo..
Peamine sõiduk: e36 universaal
Postitus Postitas ..heigo.. »
On kellelgi kogemusi, kui ruttu see aku tühjaks läheb, kui ei tarvita?
Ise kasutan ainult ühte võtit ja teine seisab niisama, vahepeal olen mõelnud et mõnda aega kasutaks teist, et lasta väheke laadida, aga mõtteks on see jäänudki:)
M3
MartenL
Peamine sõiduk: Alltrack
Postitus Postitas MartenL »
Mul oli teine võti laua sahtlis ca 1,5 aastat: töötas ikka. Raadio ja kliima seadistused olid tal ka kenasti meeles
S1lv3r
Postitus Postitas S1lv3r »
endal ei toiminud pult päris mitu kuud, kui lõpuks viitisin asja kätte võtta ja uurida mis viga,
leidsin netist mingi õpetuse kuidas pult uuesti "kodeerida"
kui õigesti mäletan siis oli nii et : võti korraks ( 1-2 sek) kõige esimesse asendisse( see kus armatuuris alumine ekraan läheb põlema, mitte süüde sisse) ja siis kohe tagasi ja võti välja, ja nüüd ma ei mäleta kumba nuppu aga hoiad lahti tegemis nuppu all ja vajutad kinni panemis nuppu 3 korda paari sekundilise vahedega hoides ülemist nuppu ikka all, ja peale kolmandat korda lased nupu lahti, siis peaks korraks kesklukk uksed kinni panema ja kohe lahti tagasi ja korras :S nii lihtne see oligi :D
Kui niipidi ei toimi, siis hoia keskmist nuppu all ja klõpsuta 3 korda ülemist, isegi tegin esimese korraga valesti.
tegu siis ikka selle rombi kujulise võtmega !
Edit : ei ole sama õpetus mis Tarmo pani, proovisin seda ka kunagi aga minu puhul toimis see mis kirjutasin..
ratteh
Postitus Postitas ratteh »
Mul endal aegajalt sama asi ja kunagi ammu juba, kui patriku juures käisin, teatas ta mulle, et kesklukuplokk on vigasid näidanud ja ühel hetkel ei käi uksed enam ei kinni ega lahti.
Tõenäoliselt minu analoogne viga ei ole mitte puldist vaid ikka kesklukust ja võibolla teilgi on kesklukk vähe sassis omadega...
1,8l E46 coupé 12/1999
erx
Peamine sõiduk: polo
Postitus Postitas erx »
umbes nädalaga läks asi sellest, et pidi teist korda vajutama nuppu et uksi lahti/kinni panna selliseks et enam üldse ei tööta nupud puldil, ja nagu ikka, ainuke puldiga võti sellel autol .... eile veel töötas mingi 5-6 vajutuse peale, aga nüüd on täiesti dead. mis ette võtta?
Razta
Peamine sõiduk: BMW E91 320d LCI 2009a
Postitus Postitas Razta »
Võti laeb ennast sõidu ajal :shock: jälle midagi uut :D
Aga see keskluku jama vist tüüpviga, patric ütles mulle ka, et kesklukk annab veateateid ja võib juhtuda et ühel heal päeval kui poodi piima järgi sõidad ei pääse sa enam nupuvajutusega autosse. Parandamine pidi kallis lõbu olema. Praegu töötab laitmatult ja loodan et jääbki nii :D
Viimati muutis Razta, 03.06.2010 19:19 50, muudetud 1 kord kokku.
ratteh
Mulle rääkis sama lugu. Vahel paneb näkku ja pole esimese korraga lahti saanud aga "palju raha" mul pole, et parandada niiet ootan viimse hetkeni ikka ära selle veaga :D
juss17
Kus asub kesklukuplokk? e46 325ci?
bmwbmw
Peamine sõiduk: Bmw e90 325i
Postitus Postitas bmwbmw »
endal ka selline jama.. üks võti juba tühi teine kasutusel see hakkab ka saama... aga kas siis nii saab et teen uksed sele võtmega lahti mis neid veel avab ja sõitma lähen tühja võtmega ja korras??.
uue võtme tegemine pidi maksma 3500.- UM is.. aga samas võtmed olemas vaja ainult akut... mul võtmed juba täpselt 10.a vanad ja akud ka kindlasti läbi...
oskate öelda kas saab tellida akut ja siis see ära vahetada ja siis uesti võti kokku panna ja siis seda meeldetuletust teha?? palju läheks maksma.. 1 võtme kohta? (aku ,meeldetuletus)
