tambets kirjutas:Kuidas ei näita? Võtsin sinu esimeses postituses antud pildi ja vedasin punase juti ümber.
01 IGNITION WIRING CYL.1-6 1 09/1994 12121742887 $317.95
01 IGNITION WIRING CYL.7-12 1 09/1994 12121742888 $317.95
02 IGNITION WIRING TUBE 2 12121729305 $42.97
03 IGNITION WIRE ? 12121705675 $11.91 +core
ONLY APPLIES TO MARTEN PROTECTED
04 Marten repeller ? 12121739479 $0.35
05 INSULATION SLEEVE ? 12121736142 $0.50
06 Circular connector ? 12121705656 $1.73 +core
08 SUPPRESSING SOCKET 1000-OHM ? 12121289825 $9.89
09 Spark plug socket 5000-OHM ? 12121710707 $26.07
10 IGNITION WIRE CYL.1-6 1 09/1994 12121742872 $41.87
10 IGNITION WIRE CYL.7-12 1 09/1994 12121742873 $41.87
11 DISTRIBUTOR CAP 2 12111725070 $129.52
12 Rotor 2 12111734110 $30.76
13 Cover 2 12111710157 $19.10
14 PROTECTION CAP CYL.7-12 1 12111702731 $14.33
14 PROTECTION CAP CYL.1-6 1 12111702732 $14.33
15 Bracket CYL.1-6 1 12111720190 $7.70
15 Bracket CYL.7-12 1 12111720191 $7.70
16 SPARK PLUG BOSCH F 9 LCR 12 10/1997 12129068016 ENDED
16 SPARK PLUG BOSCH F 9 LCR2 12 09/1998 12129070999 $8.38
Note TIS SI 12 05 98 (368)!
16 Spark plug, High Power BOSCH FGR7DQP 12 12120141871 $21.32
16 Spark plug, High Power NGK BKR6EQUP 12 12129071003 $21.32
Seal nimekirjas pole seda nr 7 asja seega ka minu autol pole seda asja... Autol pole ka reaalselt sellist juhet.
