Diagnostika vead
Hendrik_R
Diagnostika vead
Postitus Postitas Hendrik_R »
Kas keegi oskab midagi nende veakirjelduste peale kosta?
Auto 525tdsA E34 95'
1. Diagnosis DDE faults
41 Glow-duration control not functioning
Fault not currently present
Not been detected for 14 starts
Detected at:
Engine speed 705 rpm
Engine temperature 65C
2. Diagnosis EGS faults
43 Engine speed signal (td signal pin 43 on SG)
Fault has been recorded as fault 1
no or incorrect engine-speed information
3. Diagnosis EGS faults
42 Output-speed sensor n-ab
Stall-speed monitoring (pins 14-, 42+ on SG)
Fault has been recorded as fault 2
No or incorrect engine speed information
4. Diagnosis EGS faults
53 Power supply for solenoid valves (pin 53 on SG)
Fault has been recorded as fault 3
Gearbox relay in EGS SG cannot drop out
truumu
Postitus Postitas truumu »
http://www.google.ee/webhp?hl=et
Oskab küll
Kuid ausalt öeldes ei ole lahtiseletamisest huvitatud, kuna pere ninaesine sõltub sellest otseselt ;)
Ja mitte ainult minul
No hard feelings!
Ja üldse, kuidas need veateated kätte said? Carsoft?
Hendrik_R
vastus truumule
Saan aru :) , aga
äkki oskad öelda, kui palju ma rahakotti tühjendama pean umbes nende vigade likvideerimiseks. Ja veateadete kätte saamiseks oli abiks ikka "vana hea" (loe mõttetu koht) UM.
kapa
Postitus Postitas kapa »
tohib küsida miks UM mõttetu on ?
Hendrik_R
vastus
to kapa
Sellepärast, et nad ei oska midagi konkreetset kunagi öelda. Ja väga pikad järjekorrad (Tallinnas)
truumu
Saatsin PSi
