vihma sensor
Postitatud: 22.02.2017 14:07 00
Postitas toomas405
mure siis selline et 2002 e39 vihma sensor ei toimi ainult intervall,inpa veateateid ei nãita autol orinaal klaas,proovisin sensorit vahetada aga ei midagi,oskab keegi mingit nōu anda voi ise aidata
Re: vihma sensor
Postitatud: 22.02.2017 18:21 55
Postitas Volum
Kalibreerisid?
Re: vihma sensor
Postitatud: 22.02.2017 18:43 30
Postitas toomas405
midagi inpaga tegin ja üks tuttav proovis ka aga ei midagi
Re: vihma sensor
Postitatud: 22.02.2017 19:43 13
Postitas Volum
Initialisation
Due to the optical process, the rain sensor has to be adapted to the windscreen. This adaptation takes place at initialisation.
Requirement for faultless initialisation is that the windscreen glass is dry, clean and free of defects in the area of the rain sensor.
The initialisation is performed using the service function ”Initialise rain sensor” in the BMW diagnosis system. In the service function, the adaptation values in the rain sensor are deleted. This is followed by adjustment of the sensor system to the windscreen based on the following sequence:
- Switching off the rain sensor
- Switch off terminal 15 and terminal R
- Switch on terminal R and terminal 15 and wait 10 seconds
In the 10 seconds waiting period, the new adaptation values are determined and stored.
Initialisation of the rain sensor is necessary:
- After replacing the windscreen
- Fitting a used rain-driving light sensor
Note: a used sensor must be coded beforehand!
Re: vihma sensor
Postitatud: 22.02.2017 21:43 55
Postitas toomas405
mis on terminal 15 ja terminal L.ãkki seletad lollile,ei mãleta mida sal inpaga valisin aga mingit sellist protseduuri ma lãbi ei teinud
Re: vihma sensor
Postitatud: 22.02.2017 22:07 15
Postitas ttsys
O = off
KL 15 (terminal 15) or "run bus" (ignition switch run position) = ignition position 1
KL 30 (terminal 30) or "battery bus" (hot at all times) = ignition position 2
KL R (accessory bus) = ignition position 2
KL 50 (terminal 50) or "start bus" (ignition start position) = ignition position 3 (start)
Lisaks DIN72552 standard:
http://www.bosch-classic.com/media/en/b ... nungen.pdf
Re: vihma sensor
Postitatud: 23.02.2017 12:06 11
Postitas toomas405
loll tunnistada aga ei saa aru mis ja kuidas pean tegema kas algul inpaga panen kalibreerimise ja siis mängin süütega või see 2 erinevat teemat.mul inpa olemas aga ei ole seda väga kasutanud.seletage palun kohalikus keeles
Re: vihma sensor
Postitatud: 27.02.2017 08:35 14
Postitas toomas405
kas oskab keegi vihmasensorit kalibreerida.kas õpetada või ise teha,tasun vaeva
Re: vihma sensor
Postitatud: 28.02.2017 13:34 10
Postitas toomas405
Kas tõesti ei oska keegi aidata?
Re: vihma sensor
Postitatud: 28.02.2017 14:17 10
Postitas ttsys
Täpsemalt kirjeldades ei ole seal midagi kalibreerida. Ainus asi, mida saab teha on anduri initsialiseerimine.
Jääb mulje, et antud juhul pelgalt sellest initsialiseeringust ei pruugi abi olla ehk viga on mujal, kui pelgalt anduris ning selle initsialiseeringus. Võimalik, et läätsega midagi valesti(?)
Seega jooksvalt nn initsialiseeringuga peale lendamine ei pruugi lahendust tekitada. Vaja on kõik komponendid käepärast omada, et lahendus tekitada. Pelgalt initsiatiivist see korda teha jääb ilmselt väheks.
Re: vihma sensor
Postitatud: 28.02.2017 14:20 46
Postitas toomas405
proovisin ka sensorit vahetada aga lääts jäi vana kui klaasi vaadata on lääts ilusti õhku vahel pole ja ees originaal klaas
Re: vihma sensor
Postitatud: 28.02.2017 14:29 22
Postitas ttsys
Kõik tore aga siis peab süsteem reeglina kuidagi moodi ehk kasvõi hädiselt kohe töötama. Kui vee klaasile piserdamine ka kõige tundlikumas asendis mitte midagi ei muuda siis suure-suure tõenäosusega ei ravi seda ka initsialiseerimine.
Re: vihma sensor
Postitatud: 28.02.2017 14:45 21
Postitas toomas405
autol töötab intervall aga sensor järgi ei lähe
täna tuttav proovib veel boschi diagnostiga,aga mis teha soovitad
Re: vihma sensor
Postitatud: 28.02.2017 14:57 58
Postitas ttsys
BMW ISTA/D teeb initsialiseeringu protsessi nagu BMW-le vaja ning eeldatud. KTS-i teostuse kohta ei arva midagi.
Mis mul ikka rohkem soovitada. Otsusta ise ära, kas soovid maksta pelgalt süsteemi initsialiseerimise eest, mis ei pruugi mitte midagi lahendada või soov ühe korraga vajalik lahendus tekitada. Viimane eeldab, et vajadusel kõik kompenendid kohapeal olemas ning remondile järgneb nõutud initsialiseerimise protsess.
Re: vihma sensor
Postitatud: 28.02.2017 20:32 23
Postitas toomas405
mida sa remondi all silmas pead mille ma siis soetama peaks sensori koos lããtsega aga mis veel???
Re: vihma sensor
Postitatud: 28.02.2017 23:29 41
Postitas ttsys
Re: vihma sensor
Postitatud: 10.07.2017 15:06 09
Postitas toomas405
olen vahetanud sensorit teinud seda kalibreerimist ei midagi proovisin ka aktiveerimist ikka on ainult intervall. ehk oskab keegi veel mingit ideed pakkuda mis mind edasi aitab
Re: vihma sensor
Postitatud: 12.07.2017 21:39 33
Postitas MardoV
Mul ei tööta vihmasensor ega intervall. Millest alustada?
Isegi kiirusetundlikus ei tööta kojameestel ehk, kui kojamehed on kõige kiiremas asendis ja jääda seisma, siis pühivad ikka täiega edasi.
Re: vihma sensor
Postitatud: 16.07.2017 16:39 43
Postitas oke139
Alusta diagnostikast?
Re: vihma sensor
Postitatud: 17.07.2017 16:13 26
Postitas MardoV
Tegin diagnostika ja näitas et vihmasensori plokk ei tööta. Kas see mõjutab intervalli kiirust ka?
Re: vihma sensor
Postitatud: 17.07.2017 16:18 23
Postitas ttsys
Otseselt sellega seotud.
Re: vihma sensor
Postitatud: 17.07.2017 17:13 10
Postitas MardoV
Suur tänu!
Re: vihma sensor
Postitatud: 17.07.2017 20:23 05
Postitas toomas405
Minule ka mõnda ideed mida katsetada
Re: vihma sensor
Postitatud: 17.07.2017 20:45 44
Postitas ttsys
Post #4 kirjeldatud initsialiseering teha ISTA/D-ga.
Re: vihma sensor
Postitatud: 18.07.2017 14:16 12
Postitas toomas405
tehtud manuaalselt,inpaga,auto com iga ja bosch diagnostiga ei aidanud ikka ainult intervall
Re: vihma sensor
Postitatud: 18.07.2017 14:24 02
Postitas ttsys
Kui usaldad neid töövahendeid siis ju lihtne. Osta uus moodul.
Re: vihma sensor
Postitatud: 19.07.2017 00:52 20
Postitas toomas405
Olgu ostan!kus asub ja milline väljanäeb ehk pakub keegi
Re: vihma sensor
Postitatud: 04.10.2017 08:23 46
Postitas toomas405
ehk keegi pakub 2002 e39 vihmasensori moodulit
